0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | hey all, a few questions in one...
are all 261's full pressure oilers? i just read an article in the tech section explaining how to turn a 261 into a FPO. which years were and were not. is the '57 i am considering an FPO, i really want to avoid a babbit pounder
can anyone tell me where to find engine specs for a '57 261. i am in the process of purchasing the engine and the gent who is selling is doing a compr and oil press test for me..i also need to know the weight of the full engine, no bell housing clutch or trans. this is for shipping purposes.
while i am at it, can anyone recommend a good freight company. so far AAA Cooper is the best priced, but the are a hand off shipper and turn the motor over to NEMF. not that i mind but non stop would be best.
thanks
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | big ed,
1958-1962 261 Chevrolet truck engines had high-pressure engines with full-flow oil filters (metal canister style).
A 1957 261 would be a high-pressure (45 psi warmed up at idle would be real nice) engine that would use a by-pass oil filter system (metal canister style).
A 1957 Chevrolet Truck Shop Manual would have many of the engine specifications.
An engine with clutch assembly would be no more than 620 lbs.
A good engine would have 130 psi or better compression.
Tim | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | so what is the diff between the full flow and the by pass oil system. they are both a pressurized system, yes?? and the canisters for the oil filter, oil lines, and connections at the block will be the same???
thanks. has anyone seen a 57 truck shop manual online for viewing?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | oil lubrication and filter systems - old post A 58-62 factory full-flow oil filtration system used larger diameter (1/2" NPT) oil lines than the by-pass oil filters used on all other 216/235/261 engines. A '57 261 would have a high-pressure oil lubrication system and a by-pass oil filtration system (with 3/8" oil lines, I think) | | | | | Joined: Nov 2007 Posts: 29 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 29 | Is a 1954 261 has high-pressure engine with full-flow oil filters ? 39 7M | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No.
1954-1957 261 Chevrolet truck engines have high-pressure (or full-pressure) internal lubrication and a by-pass oil filtration system (unless someone converted the engine to a full-flow oil filtration system).
Tim | | |
