0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#375576 02/15/2008 5:04 AM
hey all,
a few questions in one...
are all 261's full pressure oilers? i just read an article in the tech section explaining how to turn a 261 into a FPO. which years were and were not. is the '57 i am considering an FPO, i really want to avoid a babbit pounder
can anyone tell me where to find engine specs for a '57 261. i am in the process of purchasing the engine and the gent who is selling is doing a compr and oil press test for me..i also need to know the weight of the full engine, no bell housing clutch or trans. this is for shipping purposes.
while i am at it, can anyone recommend a good freight company. so far AAA Cooper is the best priced, but the are a hand off shipper and turn the motor over to NEMF. not that i mind but non stop would be best.
thanks
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
big ed,
1958-1962 261 Chevrolet truck engines had high-pressure engines with full-flow oil filters (metal canister style).
A 1957 261 would be a high-pressure (45 psi warmed up at idle would be real nice) engine that would use a by-pass oil filter system (metal canister style).
A 1957 Chevrolet Truck Shop Manual would have many of the engine specifications.
An engine with clutch assembly would be no more than 620 lbs.
A good engine would have 130 psi or better compression.
Tim
so what is the diff between the full flow and the by pass oil system. they are both a pressurized system, yes?? and the canisters for the oil filter, oil lines, and connections at the block will be the same???
thanks. has anyone seen a 57 truck shop manual online for viewing?
oil lubrication and filter systems - old post
A 58-62 factory full-flow oil filtration system used larger diameter (1/2" NPT) oil lines than the by-pass oil filters used on all other 216/235/261 engines.
A '57 261 would have a high-pressure oil lubrication system and a by-pass oil filtration system (with 3/8" oil lines, I think)
Is a 1954 261 has high-pressure engine with full-flow oil filters ? 39 7M
No.
1954-1957 261 Chevrolet truck engines have high-pressure (or full-pressure) internal lubrication and a by-pass oil filtration system (unless someone converted the engine to a full-flow oil filtration system).
Tim
