Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, Peggy M, Jon G), 49 guests, and 4 robots.
Topics128,009
Posts1,055,296
Members48,419
#3757 03/31/2004 2:17 PM
Replacing the torque tube rear end and 3 speed tranny in my 48 half ton. Measured the stock rear end before removing, to know how far back to set the new mounts to center the tire in the fender. My measurement shows I need to set the center of the new 9 inch axel 4 1/2 inches to the rear of the center pin. Bought a set of "off set axel mounts" from No Limit Engineering. They are only off set 2 inches.
On the original touque tube rear end the mounts are not directly under the axel tube, but about 2 inches in front, so with my No Limit off set mounts the new 9 inch rear end will be in the same position as the original torque tube.
I am not understanding something??
1948 Chevy
5 window
"6" powered
#3758 04/01/2004 7:54 PM
I don't know if this will help, but take a look at a stock torque tube truck. You will notice that the rear wheel is not centered in the wheel well. At stock height, it sits foward a couple inches. I believe it this is because of the torque tube hinge set up, under load the axle would move back with the springs. If you want to center the axle, you do need to set the mounting hole farther forward.
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
