5 members (Hotrod Lincoln, papas52, Hanks custodian, Buckeye998, Canadian Dump), 130 guests, and 3 robots.
Topics128,165
Posts1,056,988
Members48,458
Will a center pumpkin out of a 58 chevy car work in an AD axle housing? Will the AD axles work in the car center pumpkin?
What would the gear ratio be in a 58 chevy car differential be?
Looking for another way to raise the gear ratio in my 52 without changing out the complete rear axle housing.
Thanks for the help.
1955-62 PU center sections are the only open drive units that will fit right in, same axle splines also. They came in 4.11, 3.9(standard), 3.7, 3.38(auto).
My Blog
ODSS President
ODSS President
I'm using a '57 3.90 pumpkin out of a truck into my '49 axle, fits like it was meant to be there and now I'm open drive (shaft). I have a '62 3sp+od, the od=.7, so, .7 x 3.90=2.73, 3rd overdrive, @2100 rpms. I go 70 mph all day long, completed a 1600 mile trip this summer, a breeze.
~ Cosmo
1949 Chevy Half Ton
This is great info guys .
So a '55-'62 pickup diffhead will fit into the earlier torque tube axle casing . GREAT !
My question is ,, just how much earlier can this be done ??
Will I be able to fit the '55 diffhead into a '46 pickup axle casing ??
Guys,,, be sure to remember that the torque-tube rear end gets some of its mounting strength from the tube itself. SOME modification will be needed to hold the rear end to the leaf springs aws they mount differently.
ODSS President
ODSS President
Oops, I forgot, got my mounts from Buffalo Ent. The axle is re-centered in the wheelwell with Buffalo mounts. You have to burn off the old Torque tube mounts with a torch.
BUFFALO
ENTERPRISES
25625 Dahl Road, Arlington, WA, 98223
(360) 652-7684
~ Cosmo
1949 Chevy Half Ton
I'm confused. If I put A 55-62 pumpkin in my torque tube 46, I need to change my spring perches ??
I already have converted to an open drive shaft setup. I took the center pumpkin out of a 55 1st series and put it in the 52 torque tube housing. This gave me an open drive shaft. To be able to use the old housing, I welded the mounts solid. There is a rubber bushing inside the mount that attaches to the axle housing and the spring. I just welded this pivot point together and didn't have to change any mounts.
May be a photo will explain what I am having trouble saying.
http://community.webshots.com/album/94991719ZcaSLu
http://community.webshots.com/photo/94991719/94993264tuafcF
http://community.webshots.com/photo/58753176/58835235DxgtTe
Seems to working very well, a couple of hard burnouts didn't brake anything. Can you do a hard burnout with a 228 GMC engine?
I have access to a 58 Chevy car and thought the center section would work in this housing. I might be able to raise my gear ratio easily.
Thanks for the input.
Arlyn
