1 members (JakeM),
129
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37503 02/10/2004 3:50 AM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | I was filling the cooling system of my rebuilt 261 tonight when the coolant started flowing out a small hole in the block just behind the exhaust pipe flange.
It's too dark and cold on the driveway to investigate further tonight but what the heck is that hole doing there? A block petcock is at the rear of the block and low for good drainage. I'm going to put a threaded plug in there tomorrow but what's the purpose of that hole?
Thanks!!! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#37504 02/10/2004 3:59 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That hole is where the throttle pivot goes in some applications. It should be threaded 5/16" coarse.
See the USA in your vintage Chevrolet! My Blog | | |
#37505 02/10/2004 4:23 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Wrap a 5/16" stainless steel bolt with some teflon tape or teflon thread sealer and screw it into the hole, unless you are using that hole for you throttle linkage bell crank. Seems kind of strange that a bolt hole will go through into the water jacket, but it does. I guess it's an emergency coolant drain.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#37506 02/10/2004 3:41 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | This is a very small hole like the one on the distributor side of the head that has the square-head plug in it. That one was drilled to provide an oil passage to the middle of the head and the oil connector. You can't even see it when the exhaust pipe is connected to the manifold. My throttle pivot is on a raised surface so it wasn't drilled all the way through.
Is there some kind of water passage on a 261 that was needed inside the block? Could this be related to the extra water holes between the block and the head of a 261?
I'm going to get a plug for it but it is smaller than 1/8" pipe thread which I tried last night.
Thanks! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#37507 02/10/2004 5:04 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Wally, up to 1959 there were two spots for throttle pivots, one 9 1/2" from rear of block and one at 12 9/16" from rear. The front hole is not raised very much and is drilled through to the water jacket. Both spots are threaded 5/16" corse thread.
#37508 02/10/2004 6:34 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Dave is the resident hole expert.  How did all this sawdust get under the hood? | | |
#37509 02/10/2004 7:16 PM | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Wally, my 261 came out of a school bus, it had the throttle pivot in the hole. I didn't put it back in and when I filled it up with water to start it, it came running out.Maybe the engines in the larger trucks used that position for the pivot.? Did your engine come out of a large truck or bus?
Tommy 59 apache 1/2t 261 short stepside | | |
#37510 02/11/2004 1:17 AM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | Tommy, Laissez le bon temps rouler!!! (Pardon my French.) We went to one of your Metairie Mardi Gras parades a few years back! Those step ladders modified to hold 2-3 kids on a shelf to watch the parade were great. Some had wheels and were used like a cart to haul an ice cooler around.
Thanks, guys. The engine man had the 261 so I don't know its source. It is indeed a 5/16" 18-thread hole. I had a hard enough time with my throttle pivot. I don't know how they could have used that hole.
Thanks, again, especially pre-68 Dave! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#37511 02/12/2004 4:28 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Wally,FYI,the 216 only had the front hole. If you are using the rear hole your linkage has been modified
#37512 02/12/2004 5:36 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Isn't it great to be able to solve a problem for a fellow Stoverbolter! A-h-h, the power of The Stovebolt Page!
