Brrrr
place holder
3 members (1954gmc9314, Ponchogl, 1 invisible), 102 guests, and 4 robots.
Topics128,272
Posts1,058,419
Members48,485
Y
Y Offline
OK, I've used the search function, and as far as I can tell, have followed the directions. Can't get the cylinder to come out. Using a paper clip in the small hole, and the ignition key, tried turning forward, backward, starting from the acc position, everything. The key just slides out of the lock when when I pull back on it with the paper clip in there after turning the key. What am I missing here? BTW, it's a 1970 GMC. Thanks!
Riding in the Passing Lane
Your cyl. is wore out & the key wont stay in. Use something that will grip the cyl. Snap ring pliers or needle nose pliers. Turn it to acess. & you can feel the spring pressure on the paper clip. turn it a little further & grab it with something. If it still won,t come you may have to spray some WD 40 or equivelent in it.
1972 Chevy c10 Cheyenne Super
Y
Y Offline
Snap ring pliers and PB Blaster did the trick, Thanks
