4 members (KEVINSKI, DadsFirstPickup, Hanks custodian, Ponchogl), 198 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
#37470 04/27/2005 5:03 AM
I'm trying to set up a linkage to my TV cable, the carb is mounted sideways with a short rod to a new hole just below the pedal rod on the rocker...works great, but I am aware of the possible drawbacks.(65 292) Langdon's note with the adapter says this can work for the moderate driving style I have.The cable travel is critical for this trans to survive and perform so I'm hoping I might get some feedback from someone who's 'been there'. This Board and it's links have taken me a long way!! Many thanks,Tom wink
65 C10 292/700R4 long fleet...Gettin closer by the day.
#37471 04/27/2005 12:05 PM
Just did it myself, albeit with an Edelbrock on a 250. Yes, the TV setup was the trickiest part of the trans swap. I put a bellcrank on the frame. I have learned that there can be no slop from the bellcrank to the carb or it throws off the TV timing - the TV cable moving while the carb linkage isn't. Been driving it for a week and a half now and it's working fine. I have an adjustable vacuum switch on order to replace the switch that cam with the Painless lockup kit. Set at 3", it might as well not even be there. By the time I hit 3" vacuum, its dropped to third or second gear. I like to have the lockup come in after fourth engaged, almost as a fifth gear.
http://www.homestead.com/chuckthetruck/Page26.html
Great info, thanks for the quick reply!Love your site! Anyone out there modify the stock (64-66) linkage to tie into the @#$% TV cable?
I am in planning to do this to a 72 truck i just picked up. I found this site to be very helpful.
Bowtie Overdrives
