8 members (FAST55, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf, 55shaker, Ponchogl), 75 guests, and 4 robots.
Topics128,065
Posts1,055,868
Members48,428
OK, so I am running out of spare time to look for a power rack to use on my GM Metric / S-10 based IFS setup for AD's. I have a corvette rack that would work, however I am looking for lower cost alternatives (or the same rack at a much better price than I am finding). I would like to find a rack with better mounting options than the Vette setup as well. I am putting this as a general shout out for pointers, opinions, ideas, suggestions, etc. I would rather not go Mustang 2 / pinto racks as that would be wrong (yes they are plentiful)
Thanks in advance.
Scott
Have you considered the late Camaro/Firebird rack?
Bill Burmeister
Was looking at them on Fleabay
1 Offline
keep us posted on your findings as anyone that had done a s-10 swap knows the steering box could be in a better spot.
Apprentice
Apprentice
Hey Scott, how about a rack out of a Dodge Dakota. A friend is building a 50 AD using the Dakota chassis. He says it's the exact length and width for the AD. No need for spacers on the front wheels or a 4x4 rearend. The power rack if I remember correctly sat on the front of the main crossmember on 2 simple brackets that could easily be fabbed by yourself. Hope this helps!
how about using the stock steering box just like when you clip a truck
1949 SUBURBAN
Originally Posted by Chevy Nut
Hey Scott, how about a rack out of a Dodge Dakota. ...... Hope this helps!
Then that goes against keeping make for make. No FOMOCO Parts on a GM, NO MOPAR parts on a GM.
I have considering this, with one exception, the stock s-10 steering geometry then needs spacers and brackets to be welded and located to the frame. My goal is something simple for someone to weld-in, and not require a locating fixture. Besides the fact that when you clip, you dont have to locate anything - its on the clip. When you are using the stock frame, you need to located everything. if off a little, steering geometry is off. I also am no keen on trimming sheetmetal. Hence the simplicity of a rack.
The GM F-body has the right width, correct ends for the GM metric / S-10 spindles and is easy to mount.
