| | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | OK, so I am running out of spare time to look for a power rack to use on my GM Metric / S-10 based IFS setup for AD's. I have a corvette rack that would work, however I am looking for lower cost alternatives (or the same rack at a much better price than I am finding). I would like to find a rack with better mounting options than the Vette setup as well. I am putting this as a general shout out for pointers, opinions, ideas, suggestions, etc. I would rather not go Mustang 2 / pinto racks as that would be wrong (yes they are plentiful)
Thanks in advance.
Scott
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Have you considered the late Camaro/Firebird rack?
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Was looking at them on Fleabay
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | keep us posted on your findings as anyone that had done a s-10 swap knows the steering box could be in a better spot. | | | | | Joined: Jan 2006 Posts: 33 Apprentice | | Apprentice Joined: Jan 2006 Posts: 33 | Hey Scott, how about a rack out of a Dodge Dakota. A friend is building a 50 AD using the Dakota chassis. He says it's the exact length and width for the AD. No need for spacers on the front wheels or a 4x4 rearend. The power rack if I remember correctly sat on the front of the main crossmember on 2 simple brackets that could easily be fabbed by yourself. Hope this helps! | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | how about using the stock steering box just like when you clip a truck | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Hey Scott, how about a rack out of a Dodge Dakota. ...... Hope this helps! Then that goes against keeping make for make. No FOMOCO Parts on a GM, NO MOPAR parts on a GM. how about using the stock steering box just like when you clip a truck I have considering this, with one exception, the stock s-10 steering geometry then needs spacers and brackets to be welded and located to the frame. My goal is something simple for someone to weld-in, and not require a locating fixture. Besides the fact that when you clip, you dont have to locate anything - its on the clip. When you are using the stock frame, you need to located everything. if off a little, steering geometry is off. I also am no keen on trimming sheetmetal. Hence the simplicity of a rack. The GM F-body has the right width, correct ends for the GM metric / S-10 spindles and is easy to mount.
