2 members (Nick in Manitou, 1 invisible), 342 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
#373960 02/11/2008 9:15 PM
Apprentice
Apprentice
1 Offline
My 12v light switch has terminlas (battery, lights, taillights, parking lights).
All the directions I have are for a 38 12v harness which i was told is the same for a 39 refer to the light switch termainals as term H, term S, term R...can anyone convert that?
Is H "headlight"
Is S "stoplight"
Is R "running lights" or "parking lights"
Regards
1fine39
1Fine39 #373993 02/11/2008 10:07 PM
Ex Hall Monitor
Ex Hall Monitor
"H" goes to the headlight junction blocks. "S" goes to the dimmer switch. "R" goes to the instrument lights and taillights. Check your e-mail. I sent you the wiring diagram.
Tiny #374039 02/11/2008 11:38 PM
Apprentice
Apprentice
1 Offline
More help as usual, Thanks tiny
David
1Fine39 #374124 02/12/2008 3:05 AM
The head light switch wire goes to the dimmer switch. Two wires then go from there to the headlight junction blocks, then to the high and low beams.
I think you are right on about what the H, S and R mean. It should be easy to determine with your multi-meter though.
