| | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 21 Apprentice | | Apprentice Joined: Feb 2008 Posts: 21 | My 12v light switch has terminlas (battery, lights, taillights, parking lights). All the directions I have are for a 38 12v harness which i was told is the same for a 39 refer to the light switch termainals as term H, term S, term R...can anyone convert that? Is H "headlight" Is S "stoplight" Is R "running lights" or "parking lights" Regards 1fine39 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | "H" goes to the headlight junction blocks. "S" goes to the dimmer switch. "R" goes to the instrument lights and taillights. Check your e-mail. I sent you the wiring diagram.
| | | | | Joined: Feb 2008 Posts: 21 Apprentice | | Apprentice Joined: Feb 2008 Posts: 21 | More help as usual, Thanks tiny David | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The head light switch wire goes to the dimmer switch. Two wires then go from there to the headlight junction blocks, then to the high and low beams.
I think you are right on about what the H, S and R mean. It should be easy to determine with your multi-meter though. | | |
