| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37397 02/01/2004 7:34 PM | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | I have two 235 motors, one a '55 and one a '56. Of course the Intake Manifolds on each of them are identical. I recently acquired an NOS manifold (which I believe is from a newer year) in which the heat riser "box" is shorter, than the ones on the '55 & '56. I was told that the NOS manifold may not work with the carb I have as with a shorter "box" the gases are not heated enough and I believe I was told the carb would run rich. Is anyone familiar with this problem, or had similar experiences with the newer type of manifold? (NOTE: The NOS manifold is DEFINATELY 235-it was attached to an NOS exhaust manifold that is exactly like the ones I have). | | |
#37398 02/01/2004 8:01 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | If you mean the height of the square center plenum where the carb bolts on, yes there are at least two styles. The shorter styles I have seen where used on trucks with a governor control between the carb and manifold.I have a shorter style on the 261 engine on our 51 truck, I tossed out the governor,the engine runs just fine with a working heat riser. | | |
#37399 02/01/2004 8:03 PM | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | As an added note to the above post, if you would like to see a photo of the two different manifolds next to each other, e-mail me at [email protected] and I will happy to send you one. Thanks  | | |
