0 members (), 256 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
Apprentice
Apprentice
Been trying to figure out, with no luck. My 1960 GMC 1000 has a v6. Someone put a small holley single barrel on it( I have no idea of it's number-has float bowl in front), but that isn't really working well. Can some one tell me what is the proper carburetor for this truck? Also, what was this v6 called? Ie: displacement?
Thank you for your input!
Just learning...
The carburator for the V-6 was a Stromburg two barrel. I don't remember the model, the 6066 pages have all the info on them plus setting a V-6 up with the correct manifold for a 4 barrel Holley. The 6 in your pickup is a 305 CID and could be an E model, our 64 had an e and our 61 two ton has a 305 C, I don't know if letter changes accured in these years or not the C was for the big trucks at that time.
Apprentice
Apprentice
Thanks for the lead. i found that in 1960:
305 A had a Holley 1904
305 B had a Zenith 228BV12
305 C had a Bendix Stromburg WW2
Now how do I find which motor I have? A,B,or C?
Just learning...
Check the engine code on the pad at the front of the engine.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
Got it: 305A, so it takes a Holley 1904....thanks guys, I really appreciate the intel,saved me days of headaches!
Just learning...
recently sold a completely original 60 gmc with the 305a and it had a 1904 from factory
1950 3100 3 windo
1951 gmc 102
1958 chevy 3200
1959 gmc 102
1963 c20
1959 buick lesabre
1961 buick lesabre
Check out 6066 gmc (google search), Jolly Goodfellow's site, has LOts of info on GMC V6. That little carb on those early engines is a real choker. Might want to see if a 305E mainifold will fit it, I put a 210 1/2 quadrajet (off a 301 Pontiac) on my 64, it purrs like a kitten. The manifold (305e) is a choker for it also, but that pontiac engine was not a big breather either. Check out their HEI conversion. Mine runs as good as a late model, no raw fuel smell, missing, ect with the modern carb (elec choke) and HEI. Well worth the trouble. You will pick up 15 hp with better breathing, might need bigger pipes, Mine is just "regular old exhaust" might put duals on one day.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
