3 members (BC59, Wally / Montana, 1 invisible),
105
0
Mod | | | Forums66 Topics128,163 Posts1,056,922 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Been trying to figure out, with no luck. My 1960 GMC 1000 has a v6. Someone put a small holley single barrel on it( I have no idea of it's number-has float bowl in front), but that isn't really working well. Can some one tell me what is the proper carburetor for this truck? Also, what was this v6 called? Ie: displacement? Thank you for your input!
Just learning...
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | The carburator for the V-6 was a Stromburg two barrel. I don't remember the model, the 6066 pages have all the info on them plus setting a V-6 up with the correct manifold for a 4 barrel Holley. The 6 in your pickup is a 305 CID and could be an E model, our 64 had an e and our 61 two ton has a 305 C, I don't know if letter changes accured in these years or not the C was for the big trucks at that time. | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Thanks for the lead. i found that in 1960: 305 A had a Holley 1904 305 B had a Zenith 228BV12 305 C had a Bendix Stromburg WW2 Now how do I find which motor I have? A,B,or C?
Just learning...
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Check the engine code on the pad at the front of the engine.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Got it: 305A, so it takes a Holley 1904....thanks guys, I really appreciate the intel,saved me days of headaches!
Just learning...
| | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | recently sold a completely original 60 gmc with the 305a and it had a 1904 from factory 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
| | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Check out 6066 gmc (google search), Jolly Goodfellow's site, has LOts of info on GMC V6. That little carb on those early engines is a real choker. Might want to see if a 305E mainifold will fit it, I put a 210 1/2 quadrajet (off a 301 Pontiac) on my 64, it purrs like a kitten. The manifold (305e) is a choker for it also, but that pontiac engine was not a big breather either. Check out their HEI conversion. Mine runs as good as a late model, no raw fuel smell, missing, ect with the modern carb (elec choke) and HEI. Well worth the trouble. You will pick up 15 hp with better breathing, might need bigger pipes, Mine is just "regular old exhaust" might put duals on one day.
64 & 66 GMC long fleetside 4x4 Cartwright, OK
