| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | How does the right inner wheel well connect to the fire wall? On the left I have a curved "Z" assembly that combos to connect the left wheel well and reinforce the parking brake. I'm assuming the right side isn't much different, however I have no pc that resembles that. If my assumption is correct, how did this pc connect to the fire wall? bolt or weld? Has anyone seen this illustrated in the '47-'50's assembly manual? section n page? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The right side is different from the left because there is no parking brake support. I think the inner fender bolts directly to the firewall.
Several guys have extensive photo-essays on the restoration of their trucks so it might be worth your while to page through some of them to see if the information you're looking for can be found there. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yea, the right inner fender on mine bolts directly to the firewall. In THIS PICTURE you can see 3 bolt heads right next to the kick panel. But, as you can tell by the condition of my cab, there is no saying that this is factory correct. | | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | Thanks for the info. Sorry 'bout being late returning reply. Had to make a quick trip to Western NC, but I'm back Thanks again for the response. JIm tools94 | | |
