2 members (baldeagle, 78buckshot), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#37352 03/10/2003 3:36 AM
1 Offline
got a question. I have a 1/2 ton 50 5 window, and i'm gonna buy a three speed tranny but it's from a passenger car. am I gonna have any problems? gear ratio or any thing else???
1950 1/2 ton 3 window
#37353 03/11/2003 2:23 AM
Any saginaw with a GM bolt pattern will fit your bellhousing but you may want to get a Patricks catalogue (check the links on this website to get to Patricks website and order the catalogue)to check the gear ratios which vary widely on these trannys. Conventional wisdom is that the trannys with two lines or marks around the input shaft are best. wink
Buzz'n Half Dozen
#37354 03/11/2003 4:27 AM
Junior Member
Junior Member
To see a list of ratios for the 3 and 4 speed saginaws go to:
www.dandltransmission.com/saginaw.html
#37355 03/11/2003 5:11 AM
nice link Denny.
Buzz'n Half Dozen
