1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#373064 02/09/2008 10:25 PM
I saw this article in the Successful Farming magazine. It is pretty interesting on how to pour babbit bearings.
It's 2 pages.
Babbit bearings page 1
Babbit bearings page 2
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
Good article- - - -but oversimplified a lot! The "fitting" procedure using Prussian blue and a scraper isn't covered at all. The babbit-pounder Chevy rods used a different babbiting procedure which resulted in a much thinner layer of bearing material than the old Ford engines and others used. Chevy rods can't be reconditioned by repouring the bearings. That's why insert bearing conversions are popular when upgrading a stovebolt engine.
Z
Z Offline
Back in the late 1950's I was a lad working on a 180,000 square acre cattle and sheep property as the off-sider to the "Windmill Expert", a full time job for both of us.
The property had 33 windmills that pumped from the underground ground water aquifier to drinking troughs for the stock.
A lot of these windmills were very old and sometimes we moved them lock, stock and barrel over new bores that had been sunk.
I remember three old gearboxes that dated back to 1917 and the bearing were originally milled from saltwater mangrove trees.
The expert and I went to the station vehicle dump one day and grabbed all of the die-cast door handles, engine parts, any kind of white metal, cooked them up in a cast-iron dutch oven and poured the molten metal directly between the block space for the main bearing and the drive journal on the crankshaft.
We let that cool for 48 hours and removed the packing. Gave it a liberal dose of penetrating oil and slowly rocked it applied pressure and after about 1 hour, got the drive shaft turning.
Assembled the gearbox and blades right up on the mast again and all were still going strong three years later, when I left, to get a life nearer the big city. Just bush innovation.
"After you skin yer knuckles, Mr Shifter ain't yer friend any more."
1942 Chevy 3/4 ton
Photo Site
1946 Chevy 5 window coupe/ute (new stray)
2000 Nissan Patrol 4x4 4.5l turbo diesel
