1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
Hi folks....Hope to get my 'birth-truck' (1955) someday soon...
can the earlier AD grill be retro-fitted to a '55 model, I like the earlier look better !
Phil
I suppse you could change the complete front end from the Cowl forward.But you won't have a '55 then. You should have been born earlier.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
If you're talking about swapping a '55 1st series, Advance Design style body grille, for a '47-'53 grille, yes it can be done. You'll just need to swap the entire front clip, of the earlier truck, to your '55 1st series. Back in the day, in my area, it was alot of '54/'55 Chevy trucks running around with '47-'53 front clips.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Lie about your age and get a '53
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Wasn't 55 a leap year...
~Jim
Ive seen the 53 style grilles "cobbled" into the 54 front fenders. It kinda works and it kinda doesnt. You have to ruin the fenders to do it. None of the bolt holes line up so you have to drill your own. You also have to cut the grille opening on the fenders square,instead of rounded at the top corners.
The filler panel(splash pan) is different. And the 54 fenders have indents for parking lights.
Hate to see ya ruin a good 54/55 front end,but its your truck.
'55 was not a leap year, but there were two different '55 models. I think if I were born in '55 and wanted a birth year truck I'd choose the one that was availble the day I was born.
I don't recall the exact model change date, but it was spring time, like March or April, so if you were born later in the year maybe you want the second series truck instead?
