3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#37300 05/21/2005 9:19 PM
A little help please! I'm having trouble identifying the straight six in my '52 GMC 2 ton. I had thought that most of these were a 270, but this apparent military surplus has a tag in the glove box saying it is 302. Could this be a mil-spec bored out 270? This seems to be a rare 2 ton. It has HD 10 bolt hubs/axles that should have been only on class 8 Cannonballs for this year. The cab and hood are not the stretched version used on class 8 conventionals, but the same as 1 1/2 tonners on down.
Terry Wofford
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
"If it ain't broke, well give me the keys and I'll be right back!"
#37301 05/22/2005 3:43 AM
Is there a serial number on the motor? Stamped on a machined pad near the distributor? If so, the first three numbers should be the motor size.
Aside from that, casting numbers are your best bet. On my 270 the numbers are below and behind the exhaust manifold. inliners.org has information to sort out what casting you have.
#37302 05/22/2005 11:17 AM
If it's a 302 then you are a BIG winner!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#37303 05/22/2005 2:02 PM
On the machined distributer mounting pad is the engine size,first three numbers indicate engine displacement.
#37304 05/23/2005 9:13 PM
Quote
So a 302 L6 was a legitimate engine size?
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
#37305 05/24/2005 1:21 PM
8
8 Offline
Yep. The 302 was the biggest of the "small" GMC 6's. Quite popular with the hot rodders of the 50's.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#37306 05/25/2005 4:40 PM
Thanks to all for the info. I found the stamping after wire brushing some paint off, it must have been painted after a rebuild sometime. It is a 302! Now the problem is finding any parts or information on it. Nobody around hear has even heard of it. Is there any books out there that would help? What I need to know is if some parts or gaskets are the same as another common L6?
Terry
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
#37307 05/25/2005 5:07 PM
8
8 Offline
Patricks will have rebuild and performance parts. They have a nice catalog, and have been working with GM 6's for many years. Check them out at Patricks
-Tim
#37308 05/26/2005 4:04 AM
Olson's Gaskets should be able to set you up with a set of gaskets. They are located in Port Orchard, WA.
http://www.olsonsgaskets.com/
Good Luck, Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
