1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37295 06/16/2004 2:49 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Working on the old 49 which hasn't run in who knows how long. I just got it after it had been sitting for ???? It has HUCK brakes, 1-1/4" diameter front wheel cylinders, 1-3/16" diameter rears.
Pulled all wheels and wheel cylinders along with master and in process of disassembling/rebuilding them (once I get the rebuild kits!)
Tonight I pulled the Parking Brake cables, and noticed that the ends of the cables in the rear brakes don't appear attached to anything!! The cable ends were just hanging there next to the backer plate.
This has got me completely confused!!!
What does the end of the cable attach to in the rear brakes? How does the brake actuate? The cable has to pull on something?? Looks like maybe mine was removed, (along with some hardware?) disabling the parking brake.
HELP!
Thanks!
Dave | | |
#37296 06/16/2004 3:11 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I can send you a picture of the brake hardware to you directly.......don't know how to post a picture online here.
Joe
#37297 06/16/2004 3:41 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Much appreciated - I look forward to receiving the pic...
Thanks! | | |
