Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (baldeagle, Hanks custodian, Guitplayer, Otto Skorzeny, Maybellene, Hotrod Lincoln, 1 invisible), 43 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#371142 02/06/2008 5:41 AM
I was told an angle finder on where the carb bolts to on the intake is at the same angle as the tranny tail shaft on a 350 auto. Is this correct?
It doesn't look right.
If it is wrong, where do I place my angle finder on the tranny?
Colin
Colin #371281 02/06/2008 4:45 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
If you place your angle finder on the base of the intake where the carb sits it should zero out. The intake is machined so when your angle finder reads zero on the carb base there is about 3* of tilt to your mtr/trans which is the correct angle. This is where you get your angle for the mtr/trans...Joe
#371387 02/06/2008 8:50 PM
Put your angle finder on your starter motor. It is in line with your driveline.
Cletis #372769 02/09/2008 3:51 AM
Perfect!
Thanks guys
