5 members (Peggy M, klhansen, TooMany2count, Millenimech, dwreills), 33 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#371750 02/07/2008 5:04 AM
I'm in the process of rebuilding my spare 56, 235. One of the jornals in the crank has a scratch around the center of it. It is probably.010 deep. What is the down side of this scratch? It runs all the way around the center of the jornal. The rest look good.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
GEC52 #371816 02/07/2008 1:52 PM
Subscribing to this thread
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I would measure the journal with a micrometer. You might have significant wear on the journal, which would require grinding or rebuilding to restore the proper surface.
Don't guess at the condition in hopes that it will be alright.
Harvester
If it's a "spare" engine I'd be tempted to polish up the journal with 1" crocus cloth and as Harvester pointed out, make sure that it wasn't egg-shaped. The cloth-backed abrasive belt material works well at smoothing out minor nicks or imperfections and is available at most automotive supply houses off a roll by the foot. You've just got to be careful to keep any of the aluminum oxide abrasive material from entering the oil passages. I've added a little oil to the belt to hold the abrasive.
The polishing action is much like buffing the polish on a pair of shoes. Might be considered pretty "old school" but I've salvaged cranks that were nicked by a rod bolt when the piston was slid into a cylinder.
Won't cost you a mint and might just keep that spare engine running without too big of an investment. However, I'd be sure to use a new insert or even better yet a full set.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
If it's just a scratch, with no high spots to gouge the bearing, no problem. I'd shoeshine it with fine-grit emery cloth, measure it with a micrometer to make sure the shaft is round, and give everything a good cleanup. The scratch will just pool oil under the bearing.
I would not use Emory cloth, too gritty. I would use crocus cloth (red iron oxide)with light oil. Clean it up with thinners after.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #372132 02/08/2008 12:04 AM
take it to your local machine shop get opinion go from there,,turning a shaft cost about $100 cheap if you rebuid and it comes apart...doc
