6 members (‘37ChevyPU, TUTS 59, baldeagle, Guitplayer, tclederman, Leo), 95 guests, and 2 robots.
Topics128,050
Posts1,055,674
#370486 02/04/2008 11:21 PM
Hi,
I've just stripped my 1941 3/4 ton Chevy brakes to find that someone has stripped all the shoes, springs etc :-( Probably to restore and then they just gave up...
I can manage to find all the new bits I need from Jim Carter except the actuator bar/atriculating link/anchor pin see Fig 1.
I require front and back sets and would be happy to get used ones.
Any help with who could supply these to Scotland.
For those who believe, no proof is necessary.
For those who don't believe, no proof is possible.
41 Chevy
Dalbuie #370525 02/05/2008 12:59 AM
Before anyone could answer we need to know if your truck has 11 or 14 inch brakes. The 3/4 ton was supplied both ways.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #370686 02/05/2008 10:26 AM
The front and back drums are the same - 11 inch.
41 Chevy
Dalbuie #370687 02/05/2008 10:38 AM
In your profile you list a '41 1/2 ton , in your first post it is a 3/4 ton , are there 2 trucks or is it a typo? Are the brakes the same type on both trucks?
Dusty #370690 02/05/2008 11:15 AM
I created the profile when I bought the truck - as a 1/2 ton - but when it arrived, and after doing some checks I identified it as a 3/4 ton.
I've just been out to measure the drums and they are 11 inch on the front and back.
I've updated my profile, thanks for the nod.
41 Chevy
Dalbuie #370785 02/05/2008 5:56 PM
If you do not find these links, I can send a detailed drawing of the ones on my ’41 ¾ ton. They look to be fairly easy to fabricate.
Kip's41 #370845 02/05/2008 8:09 PM
I just asked 'cause I still have the links off my '40 from when I changed the brakes to Bendix. Are they likely to be the same?
Dusty #371183 02/06/2008 10:18 AM
Thanks.
The Jim Carter catalogue says the brake shoes are the same from 36-50 as are all the springs etc so they are very likely to be the same.
41 Chevy
Dalbuie #371754 02/07/2008 5:07 AM
Do you need the handbrake link off the rear shoes? 1 each side and the ecentric adjusting bolts? WHAT ABOUT THE HUGE u SHAPED MOUNT FOR THE FRONT SHOES? THIS WILL ADD A BUNCH OF WEIGHT TO THE PARCEL oops ,,, darn caps lock .. I just dug this stuff outta the shed , 3kgs , without packaging. Let me know.
Dusty #371826 02/07/2008 2:12 PM
Hi Dusty,
I have the 4 large U shaped mounts that the shoes attach to and the park brake cable clips.
I'm sure I don't have the handbrake link - all I have is 2 cables coming into the drum and was wondering how the handbrake attached - any pictures :-)
I was also under the truck looking at the park brake lever and think there may be a ratchet - or something - missing from here. If you have any pictures of what should be here that would be great.
Very interested in the parts you have (except the U brackets) - let me know what it will cost, including the packaging and I can pay by PayPal, cheque or whatever mechanism you want.
Many thanks
PS
Love your truck, and think I may add a canopy to mine - could be handy given the weather in Scotland :-)
41 Chevy
Dalbuie #372007 02/07/2008 8:36 PM
OK, the parts are a swap for a metal Scottish car badge , AA or similar , http://motors.search.ebay.co.uk/grille-badge_Car-Badges_W0QQdfspZ1QQsacatZ72185 like something off this page , I will post what I have , hopefully it will be enough to see you right. PM me your email .
Dusty #372083 02/07/2008 10:50 PM
Dalbuie,
I've got some brake parts in the shed as well. Let me know if there is anything else that you need after you get the parts from Dusty. Also if there are any other wee bits and pieces that you need for the truck. I'm coming home (to Scotland) in May for a holiday and I can bring some wee things over. Wee things mind no bloody engine blocks or diffs!!!
All the best
Mozzie
Dusty #372109 02/07/2008 11:33 PM
Many thanks, have PM'd the details smile
41 Chevy
mozzie #372115 02/07/2008 11:41 PM
Hi Mozzie,
Where about is home?
I have a big list about to go on order with Jim Carter (or another supplier depending on his quote) so this, and a few electrical bits I can get locally, will hopefully get it on the road.
I'll keep in touch as I re-build in case there are any bits I forget about, or haven't thought about since the drums are all empty just now.
..unless you can get 2 new running boards in hand luggage :-)
41 Chevy
Dalbuie #372582 02/08/2008 8:43 PM
Hell0o mate,
I'm originally from just ourside Bannockburn. I'll have a look in the shed after work today and see what brake parts I have. I remember the time when you could just about get a pair of running boards on as hand luggage!!
All the best
Bob
mozzie #372660 02/09/2008 12:07 AM
Thanks. A lovely part of the country, and very famous for us Scots :-)
Took the truck bed to bits over the last 2 days - and burnt out 4 grinding disks and a grinder!! A weekend to remove the bed sides and, fenders and running boards which will then give me access to the chassis to rub doen and paint.
Have all the other bits on order, but have about 5 weeks till they arrive :-(
41 Chevy
Dalbuie #373678 02/11/2008 3:53 AM
Parcel posted today Dave, look for it in 2 or 3 weeks , let me know if it doesn't turn up in a month. You will still need to find the 2 handbrake push rods , they are about 5" long and 3/8" dia with a split in the end that slips over the center rib of the shoe , and the cut out in the handbrake lever (supplied) should be a pic in the w/shop manual.
Yep , I just looked, in the '47 manual it is shown as a link in a pic for adjusting the rear brake toggle. Pretty much hidden by the shoes and axle flange , but the end with the spring can be seen just below the ecentric bolt . Maybe Carters will have the part , the springs are in the parcel.
Regards.
Dusty #373919 02/11/2008 7:39 PM
Many thanks Dusty, I'll put out a help call for the push rods.
Mozzie said he had a few bits in his shed.
If you PM me your address I'll get the badges to you.
Cheers
41 Chevy
Dalbuie #373921 02/11/2008 7:58 PM
PM sent.
Dusty #374723 02/13/2008 6:57 AM
Hi Dave,
I had a look in the shed but don't have the pushrods you need. Just been back over the parts again to make sure that I didn't miss anything but no luck I'm afraid. Might pay to put an ad in the parts wanted section. I'm sure you won't have much problem getting a couple.
Cheers
Bob
mozzie #376217 02/16/2008 8:41 PM
Thanks. I have an order coming for lots of parts including:
"4 of Brake Hardware Set All 4 Wheel Stations. Articulating link & anchor pins etc"
Hopefully with this and the stuff from Dusty I'll have everything - if not I'll put out a HELP!
Cheers
41 Chevy
