| | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | I have a 1941 Chevy pickup .. (actually I have two of them)
One of them is dripping gas at the fuel shut-off valve at the bottom of the gas tank.
Does anyone know the specs for a replacement valve? And where to order one?
Thanks in advance for your help!
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Could be as simple as taking it apart & putting an O-ring in it, IF they have them...Joe | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Any hardware store should have replacement valves. The valve (petcock) in mine had a 4" extension that ran though the floor and into the tank. I substuted a 4" brass nipple & 90° petcock with NPT x compression fittings. I tried taking the guts out of the new petcock & using them in the old valve but it wouldn't work right.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have repaired several similar valves by first loosening the stem packing nut, screw the valve part all the way out (with nut too), then remove the old packing from inside nut, and replace with one or two small appropriately sized O-rings, reassemble, and snug the packing nut just enough to put some resistance on the valve and stop the leak, but not so tight you can't move the valve.
Grigg
