| | | Forums66 Topics128,087 Posts1,056,119 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37122 04/03/2003 6:04 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I am in need of some info about the amount of distance there should be between the TO bearing and the fingers on the pressure plate. It seems I have about 1"+ with the Adjusting Rod nut all the way to the end. Kook asked if I had the right pressure plate. Got it from Jim Carter so I believe it is right. Seem that the Adjusting Rod needs more length. Any ideas? | | |
#37123 04/03/2003 7:14 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | Funny you should bring this up now--I'm in the middle of a clutch job on my 63 pickup. The manual I have says there should be 1/8 to 1/4 inch between the TO bearing and the diaphragm fingers, which is equal to about 3/4 to 1 inch of movement at the pedal. Hope this helps you.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#37124 04/03/2003 7:29 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | SHould be about 3/4 in. to 1 in. of pedal movement(free-play)
#37125 04/12/2003 4:48 PM | Joined: Apr 2003 Posts: 5 Member | | Member Joined: Apr 2003 Posts: 5 | Could you have the wrong t/o bearing. Chevy used basically 2 bearings -- a short bearing (1.25 " ) and a tall bearing (1.87 ") | | |
