Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Otto Skorzeny, DHedrick, TexasFarmTruck, Joe H, Sedgewick, Charles in CA, crenwelge), 153 guests, and 4 robots.
Topics128,282
Posts1,058,496
Members48,490
#37122 04/03/2003 6:04 PM
I am in need of some info about the amount of distance there should be between the TO bearing and the fingers on the pressure plate. It seems I have about 1"+ with the Adjusting Rod nut all the way to the end. Kook asked if I had the right pressure plate. Got it from Jim Carter so I believe it is right. Seem that the Adjusting Rod needs more length.
Any ideas?
Junior Member
Junior Member
Funny you should bring this up now--I'm in the middle of a clutch job on my 63 pickup. The manual I have says there should be 1/8 to 1/4 inch between the TO bearing and the diaphragm fingers, which is equal to about 3/4 to 1 inch of movement at the pedal. Hope this helps you.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
SHould be about 3/4 in. to 1 in. of pedal movement(free-play)
Could you have the wrong t/o bearing. Chevy used basically 2 bearings -- a short bearing (1.25 " ) and a tall bearing (1.87 ")
