| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | I'm having trouble determining what regulator I have on my truck, the part # is P&D VR-117H. I was under the impression the truck was still running on a 6-volt system, but after cleaning the engine compartment out I noticed stamped on my generator plain as day, 12V. So I'm trying to determine if the voltage reg, is also a 12v or do i need to replace. Thanks for any help | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a cheapy volt/ohm meter & put it across the bat or hot term on the regulator or horn relay. If it reads about 12 volts you have a 12 volt system. Start the truck engine & rev the engine a little above idle. The voltage should go to about 14.0 volts on a 12 v. system or about 7.2 on a 6 volt system. If this happens your system is working & you know which one you have. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | What battery is in your truck and what year is your truck? A 12-volt regulator could be set down to 9-10 volts, I'm not sure how low that will go, but that level will severely over-charge a 6-volt battery.
Harvester | | |
