| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I was told an angle finder on where the carb bolts to on the intake is at the same angle as the tranny tail shaft on a 350 auto. Is this correct? It doesn't look right. If it is wrong, where do I place my angle finder on the tranny?
Thanks Colin | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | If you place your angle finder on the base of the intake where the carb sits it should zero out. The intake is machined so when your angle finder reads zero on the carb base there is about 3* of tilt to your mtr/trans which is the correct angle. This is where you get your angle for the mtr/trans...Joe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Put your angle finder on your starter motor. It is in line with your driveline. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | | | |
