| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 48 | Another question from one of the beginners... We have a 1&half ton fc303 GMC.(248 engine & Muncie 420 tranny) I've established that the clutch plate and the pressure plate are a larger size than smaller trucks. We're waiting for money to order these parts. What about the throwout bearing? Is there a different one needed for the bigger trucks? Or can I use the same one from 1/2 ton trucks? I see one here: http://www.truckandcarshop.com/trucks47_59/t47_058.html | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy turpentyne, according to my clutch catalog the throwout bearing should be the same as the light trucks, hope that helps. | | |
