| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37074 04/20/2003 10:33 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Last week when Teen48Flatbed and I retrieved his '48 2-ton, we had to drive it 160 miles in low-range because it kept popping out of high-range.
Initial checking revealed that the 'high' side of the vacuum unit wouldn't hold vacuum while the 'low' side would. Pulled the unit off and found oil on the 'high' side. First local parts store I went to didn't offer much hope of having the oil seal until the counterman saw the numbers on the original seal. Cross reference is to a Chicago Rawhide 12336 of which he had several in stock.
Put it back together and now it holds vacuum but it still jumps out of high range. Pulled it apart again and this time I pulled the bolt/spring assembly out of the shifter shaft and lo and behold, some yahoo P.O. had tightened the spring down to the point that it wouldn't compress any further. Overall length is supposed to be 3-1/2" and it was right at 3". Readjusted said spring and she's a shiftin' fool now.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#37075 04/20/2003 10:40 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Sounds like you guys did some nice detective work there..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#37076 04/20/2003 10:44 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I absolutely love shifting high low in my dump truck. It makes it sound like a real truck running through all the gears.
54 3100 with 235 62 flatbed dump C60 with 261
