| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | The passenger's side window squeals very loudly when first being rolled up from the full down position. I've greased everything inside the door that I can reach, and fired off a full can of WD-40 in the general direction of areas that I can't reach. No effect.
Any suggestions? Could it be that the squeal is actually coming from the window channel rather than inside the door?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most of that type of noise is the window abrading the channel. Your channel fuzzies (theres a technical term for you) probably need replaced. A liberal dose of silicone spray can help. It would be best to pull the trim panel & spray directly into the channel. If you don't want to do that you can sometimes spray a ton into the channel you can get to, then roll the window up to coat the glass and roll it down to spread it in the lower channel. It usually takes several "applications" for that method to work, if it works.
| | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Thanks. I'm getting really good at pulling that panel off so I try starting from the bottom.
