3 members (Lightholder's Dad, baldeagle, Hotrod Lincoln), 68 guests, and 1 robot.
Topics128,014
Posts1,055,333
Members48,419
#370494 02/04/2008 11:46 PM
The passenger's side window squeals very loudly when first being rolled up from the full down position. I've greased everything inside the door that I can reach, and fired off a full can of WD-40 in the general direction of areas that I can't reach. No effect.
Any suggestions? Could it be that the squeal is actually coming from the window channel rather than inside the door?
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
Ex Hall Monitor
Ex Hall Monitor
Most of that type of noise is the window abrading the channel. Your channel fuzzies (theres a technical term for you) probably need replaced. A liberal dose of silicone spray can help. It would be best to pull the trim panel & spray directly into the channel. If you don't want to do that you can sometimes spray a ton into the channel you can get to, then roll the window up to coat the glass and roll it down to spread it in the lower channel. It usually takes several "applications" for that method to work, if it works.
Tiny #370733 02/05/2008 2:51 PM
Thanks. I'm getting really good at pulling that panel off so I try starting from the bottom.
Moderated by  ndkid275, Phak1
