1 members (Eileen),
99
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 30 New Guy | | New Guy Joined: Sep 2007 Posts: 30 | I have a rear axle form a 57 chevy truck under my 53. I would love to have both wheels spinning...is there a list of interchange for a posi for this rearend? I tried some searching but found no definitive answer.
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I read in John Gunnel's book about 46-72 Chevy pickups (I forget the title, sorry) that Chevy first offered their Posi-Trac (positive traction/ limited slip) rears in 59 trucks. Finding and identifying one may be a bigger challenge. Probably someone with knowledge will respond soon.
Professional Novice
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The limited slip rear used was a spicer 45. The HO33 was likely to be the rear used in a 57. The HO33 does not have positraction or limited slip setups available for it. There are also only 2 gearsets you will find for it... 3.90 or 3.38. If posi traction or limited slip is a requirement for you... you will likely have to find another axle.
It was a priority for me in my 1940 gmc, so I ordered an IMCA modified ford 9 inch. You can get them in any width, bolt pattern, and strength you can imagine. Not to mention it has a virtually infinite sellection of gears, positractions and limited slips available for it. Best of all it was all new, and I didn't have to crawl under a bunch of trucks at the wrecking yards with a tape measure to find one. | | |
