1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 19 New Guy | | New Guy Joined: Mar 2007 Posts: 19 | I was about to replace the rear shackle bolts in the springs of a 51 GMC, but I'm unsure of the best way to remove or re-round the eye so that the new bushing and bolt can be inserted.... any ideas? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I took my main leafs to our local spring shop and he tightened the eye and installed the bushing. I asked him if it is done with heat and he said absolutely not. They have machines for doing these things. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Go to the TECH TIP page. There is a description of a DIY Bushing Puller in the Axle section. It works too.I and many others here have made and used one to success.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think the tech Tip will show you how to correct for a worn spring eye. You need some special machinery forthat. | | |
