5 members (Gray_Ghost, Hotrod Lincoln, klhansen, 2 invisible), 96 guests, and 1 robot.
Topics128,051
Posts1,055,729
#370054 02/03/2008 11:00 PM
I was about to replace the rear shackle bolts in the springs of a 51 GMC, but I'm unsure of the best way to remove or re-round the eye so that the new bushing and bolt can be inserted.... any ideas?
I took my main leafs to our local spring shop and he tightened the eye and installed the bushing. I asked him if it is done with heat and he said absolutely not. They have machines for doing these things.
1951 1 Ton Completed
truckernix #370165 02/04/2008 4:18 AM
Go to the TECH TIP page. There is a description of a DIY Bushing Puller in the Axle section. It works too.I and many others here have made and used one to success.
Drew
DrewP #370630 02/05/2008 4:22 AM
I don't think the tech Tip will show you how to correct for a worn spring eye. You need some special machinery forthat.
