| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37049 11/11/2003 4:26 AM | Joined: May 2002 Posts: 27 Member | | Member Joined: May 2002 Posts: 27 | HEY ALL, I'M GOING TO CHECK MY 292 CRANKSHAFT MAIN AND ROD JOURNALS TOMORROW AT WORK AND I'M CURIOUS TO KNOW WHAT I SHOULD DO IF IT NEEDS TO BE GROUND. I WOULD LIKE TO SEND THIS CRANKSHAFT OUT AND HAVE IT GROUND AND BALANCED. I'VE BEEN TOLD THAT I CAN BUY ONE ALREADY GROUND, BUT NOT BALANCED. SEEINGS HOW I WANT TO MAKE THIS A PERFOMANCE ENGINE(WITHIN REASON THAT IS)I THINK ANYTHING THAT HAS METAL GROUND FROM IT SHOULD BE BALANCED AFTERWARDS. AM I BEING TOO PARTICULAR FOR THIS APPLICATION? ANOTHER QUESION: IF IT TURNS OUT THAT MY CRANKSHAFT IS WITHIN SPECS., IS IT SAFE TO SAY THAT GM DID ITS JOB IN BALANCING IT AT THE FACTORY? THANKS GUYS, BO | | |
