7 members (Phak1, Jon G, sron48, MickeyP, Stovebolt48, lumbersawyer, FAST55),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,188 Posts1,057,333 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Have removed the steering wheel and horn cap on 62 c-10. My turn signal knob was removed at some point and I now would like to repair and replace mechanism in the steering column. Does anyone have pictures of what the turn signal linkages should look like? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I do not have any good photos of the turn signal mechanism, however, there are many great "exploded-view" illustrations in the 1963 Chevrolet Truck Shop Manual (covers 1960-1963) and the 1960-1966 Chev/GMC Truck Assembly Manual, showing the turn signal mechanism. I recommend these books for anyone who owns a '60-'66 Chevy Truck. They are available at: www.lmctruck.comwww.classicparts.comwww.bowtiebits.comwww.oldchevytrucks.comamong others. Good luck with your project and I hope this information is helpful. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks. I have the shop manual but I did not think to look in the others. Thanks for reply. | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | The 1960-62 trucks had a pop metal oval type ring that has 2 tabs for the "cancrlling" of the signal. There is a pitment arm that connects this ring to a cable.
This cable runs down to the very bottom of the steering column where the turn signal switch is located.
You can pick up the metal "o" ring, bolt, turnsignal arm, etc in the truck parts catalogues. David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks for response. I have a cable external to steering col. and a switch at the base of the col. as you suggest. Not sure I know how the linkages come together. I can not find the exploding views. Do you have a picture? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Chance I can resurrect this question. I couple of us are in a struggle. I have not found the exploding view of the 62 column and a good description of installation of column bearing and turn signal mechanism. My truck did not arrive (years ago) with the innards of the column so I had nothing to take picture of or a sequence to reverse. I am not real confident that I can just order the parts and install. Would like to know what I am in for prior to purchase.
I have a suspicion the bearing needs replacing and that is why I may tackle the turn signal finally. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | HB, if you can post a picture looking at your column from the top, without wheel attached, I can compare to my 1960 and see if I can help. I need to see what all you are missing. .
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | OK. Will get after that soon. The 66 is taking my freetime over the next few weeks. | | |
