| | | Forums66 Topics128,050 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i see they make a water base paint that looks real good get it the way you want and then you spray a urathane clear over it. is this paint safer not as flamable and hard on lungs. im thinking about trying some out | | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | If I'm not mistaken, I believe they're starting to use a lot of water borne paints in Cali. due to the VOC compliances. I was told that it was just a matter of time before they made it over here to the east coast. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Its still a bad idea to breathe the water based paint while spraying because breathing any particulate can cause lung problems later on, even just saw dust. However, a decent VOC mask is safe with the water based base coat. The top coat is probably nastier with some isocyanates in the hardener.
I have been wanting to try some of that stuff too. I may paint my rototiller and see how it holds up but I have several other projects I need to do first.
If you try it, a report would be really nice!
