| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Hello All
I'm looking for the net hp and at what RPM that would be stamped in the I D tag on the door frame. I have a 1949 3100 with a 216 in it. Im the Gm manual it is listed as 29.5 hp SAE but no RPM. Can anyone tell me were i can obtain this imfo.???
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | You'll find the info in the owner's manual..Reprints are available..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Looked in the owners manual and found HP but not at what RPM.
| | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Yes found the info at your web site
THANK YOU
