2 members (WICruiser, Joe H),
148
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 9 New Guy | | New Guy Joined: Jan 2008 Posts: 9 | I am trying to remove a gas tank from a 1938 Chevy 1/2 ton pickup, and removed the two straps and the grommet to the filler but still can't get it to come out. Is there something I am overlooking or do I need a bigger hammer? Any help is appreciated, I'm a new member and first timer when it comes to repairing this 38 hot rod. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I assume you have removed the fuel supply line which runs form the bottom of the tank to the fuel pump. Other than that, the tank should come loose. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Welcome to the 'bolt. I'm sorry you're rodding it instead of restoring it but having said that anything's better than the crusher. If you have your straps off & the fuel line removed it should just lift out. Hopefully someone in the past didn't glue it in. Does it move some, just won't come all the way out or is it still solidly in place as though there still fasteners in place?
| | | | | Joined: Jan 2008 Posts: 9 New Guy | | New Guy Joined: Jan 2008 Posts: 9 | Thanks for the replys, the straps were off and line disconnected but it was hung up on a petcock coming from the tank underneath. As far as rodding it, I had to, it already had been done with a 350,auto and 12 bolt rear end, they even chopped the frame and shortened it. Sad but still a nice truck. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | If it's hung on the petcock just remove the petcock. It's a normal RH NPT thread. Righty tighty, lefty loosey.
