Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (3B, kades51, TooMany2count), 134 guests, and 4 robots.
Topics128,283
Posts1,058,513
Members48,490
#369592 02/02/2008 4:53 PM
I am trying to remove a gas tank from a 1938 Chevy 1/2 ton pickup, and removed the two straps and the grommet to the filler but still can't get it to come out. Is there something I am overlooking or do I need a bigger hammer?
Any help is appreciated, I'm a new member and first timer when it comes to repairing this 38 hot rod.
I assume you have removed the fuel supply line which runs form the bottom of the tank to the fuel pump. Other than that, the tank should come loose.
Joe smile
Ex Hall Monitor
Ex Hall Monitor
Welcome to the 'bolt. I'm sorry you're rodding it instead of restoring it but having said that anything's better than the crusher. If you have your straps off & the fuel line removed it should just lift out. Hopefully someone in the past didn't glue it in. Does it move some, just won't come all the way out or is it still solidly in place as though there still fasteners in place?
Tiny #369980 02/03/2008 7:41 PM
Thanks for the replys, the straps were off and line disconnected but it was hung up on a petcock coming from the tank underneath. As far as rodding it, I had to, it already had been done with a 350,auto and 12 bolt rear end, they even chopped the frame and shortened it. Sad but still a nice truck.
Ex Hall Monitor
Ex Hall Monitor
If it's hung on the petcock just remove the petcock. It's a normal RH NPT thread. Righty tighty, lefty loosey. grin
