6 members (Chris's 46 / 515, Peggy M, Hotrod Lincoln, JW51, Otto Skorzeny, 1 invisible), 86 guests, and 1 robot.
Topics128,042
Posts1,055,597
#369511 02/02/2008 6:22 AM
Is there an aftermarket manifold or adapter that will allow me to use a Holley (or actually a Demon) 2 bbl on a 235? The engine is otherwise stock. I run a Demon on my street/strip car and love the adjustability of it. I would love to be able to install one on the truck also. All the manifolds I see are set up for multiple singles, which is great for nostalgia, but not what I'm after.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #369513 02/02/2008 6:32 AM
"MONGO"
"MONGO"
Clifford has one: Intake
4 barrel plate
That should allow you to use the demon carb.
I've got one I'm planning on using with a Holley 350 CFM 2 barrel with an adapter on my 261
Steve
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
