| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Is there an aftermarket manifold or adapter that will allow me to use a Holley (or actually a Demon) 2 bbl on a 235? The engine is otherwise stock. I run a Demon on my street/strip car and love the adjustability of it. I would love to be able to install one on the truck also. All the manifolds I see are set up for multiple singles, which is great for nostalgia, but not what I'm after.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Clifford has one: Intake 4 barrel plate That should allow you to use the demon carb. I've got one I'm planning on using with a Holley 350 CFM 2 barrel with an adapter on my 261 Steve | | |
