8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny), 125 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#36944 04/07/2003 9:12 PM
After searching the archives and coming up empty, I have a question for all of you pickup lovers. How do you remove the in-cab gas tank? I have the remains of a '55.1 Chevy pickup that I am parting out, but the gas tank doesn't seem to want to leave. We unbolted the straps, but it is still firmly in place. I'd like to get the tank out and sell it, it seems to be in excellent condition.
1954 GMC De Luxe COE
#36945 04/07/2003 9:14 PM
Did you take the valve out of the bottom and disconnect the filler neck on the side ?
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#36946 04/07/2003 9:20 PM
I didn't know about the valve, thanks for the quick advice. The filler neck is still connected, but that is easy - I was leaving it in place to keep the tank from falling over.
#36947 04/10/2003 11:57 PM
I removed the tank in my 41 not too long ago. It was over half full and I had no where to drain it. Unfortunately mine didn't have a shut off valve either. I just left the line on and disconnected it from the front and pulled it out line and all. It was heavy though!
#36948 04/11/2003 1:38 AM
I usually break the line at the fuel pump to drain it if it doesn't have a petcock. The AD tanks are great, they have a petcock and a drain plug.
Paint & Body Shop moderator
