0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36872 05/22/2003 4:13 PM | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | IN MY 53 AD IF THE TRUCK SITS FOR A LONG PERIOD OF TIME THE GAS RUNS BACK TO THE TANK. 1. IS THIS COMMON? AND 2. WHAT CAN I DO TO FIX THIS? ANY SUGGESTIONS WOULD BE GREAT. THANKS | | |
#36873 05/22/2003 9:50 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MacDaddy,
1. What is a long period of time?
2. Is your gas tank behind the front/driver's bench seat?
3. What do you mean by "gas runs back to the tank"? Do you mean the gas line goes dry (drains/leaks dry)?
It most likely does not drain into the tank unless it is siphoning back into the tank (panel/suburban). If it is siphoning into the tank, there might be an air leak near the carburetor?
Maybe someone else will have better advice.
Good luck, Tim | | |
#36874 05/22/2003 11:56 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It sounds like your fuel pump is on the way out. There is a check valve built into it. Make sure it isn't draining back into the crankcase!
#36875 05/23/2003 1:58 PM | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | TIM A LONG PERIOD OF TIME IS A WEEK - MONTHS. YES BEHIND THE DRIVERS SEAT, AND THE LINE GOES DRY. WE THINK ITS A FUEL LINE PROBLEM AND LIKE YOU SAID ITS SYPHONING BACK TO THE TANK. IF I RUN THE TRUCK EVERYDAY IN GOOD WEATHER I DON'T HAVE A PROBLEM. I WAS THINKING OF REPLACING THE FUEL LINE AND SEEING IF THAT WOULD HELP. | | |
#36876 05/23/2003 4:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I assume you have the one barrel Rochester "Leakmeister Special" for a carb. More than likely the problem lies in the carb, which is next to impossible to seal properly.
If your fuel line is all steel tube from the tank to the carb, you probably don't have a problem there. If the steel tube is spliced to rubber hose, there's a good chance for a leak. If so, get some Permatex Hylomar sealant (gasoline compatible) and seal the connections.
Fred 52 3600 69 C-10
#36877 05/23/2003 5:46 PM | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | FRED I DO HAVE A ONE BARREL ROCHESTER. WHEN YOU SAY LEAKING DO YOU MEAN LEAKING SO I CAN SEE A PUDDLE ON THE FLOOR, OR IS IT LEAKING TO SOME WHERE ELSE? I ASK BECAUSE THE ONLY LEAK I HAVE IS A OIL LEAK. | | |
