1 members (baldeagle),
55
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | OK, I've read all the info on this site and many others. The engine in my 5700 has a casting number on it --3738307 and the code above the starter seems to be 00N4. I thought the first one was supposed to be A-L ? Spare engine is 3835911 and 00N3. Blocks look different from each other, but both have 4 screws on valve covers and low water pumps. I put alternator bracket kit on the first engine and had to space out the mount because it hit another boss in the block below it. The other engine uses a bracket the bolts to the block just above the oilpan mount. Help Mr. Wizards !!! What do I have? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Look on the flat spot next to the distributor hole...it should tell you what it is...
Geoff
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3835911 might be a high-pressure 235 block from 1953 (Powerglide), or 1954, or 1955
3738307 might be a 1957/58 high-pressure 235 block (passenger car)
"might be" means that the information came from various sources on the Internet (not from a GM document).
Tim | | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | Thanks Geoff, I finally found some info that shows the 5911 to be a 54 and the 8307 to be a 58/59 truck or a 58-60 passenger. Both are 235's. I guess the way this works is tomorrow new info will prove all that wrong ! LOL | | |
