Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WarEagle1, 1 invisible), 172 guests, and 6 robots.
Topics128,284
Posts1,058,522
Members48,490
#36872 05/22/2003 4:13 PM
IN MY 53 AD IF THE TRUCK SITS FOR A LONG PERIOD OF TIME THE GAS RUNS BACK TO THE TANK.
1. IS THIS COMMON?
AND 2. WHAT CAN I DO TO FIX THIS?
ANY SUGGESTIONS WOULD BE GREAT.
THANKS
#36873 05/22/2003 9:50 PM
MacDaddy,
1. What is a long period of time?
2. Is your gas tank behind the front/driver's bench seat?
3. What do you mean by "gas runs back to the tank"? Do you mean the gas line goes dry (drains/leaks dry)?
It most likely does not drain into the tank unless it is siphoning back into the tank (panel/suburban). If it is siphoning into the tank, there might be an air leak near the carburetor?
Maybe someone else will have better advice.
Good luck,
Tim
#36874 05/22/2003 11:56 PM
It sounds like your fuel pump is on the way out. There is a check valve built into it. Make sure it isn't draining back into the crankcase!
Paint & Body Shop moderator
#36875 05/23/2003 1:58 PM
TIM A LONG PERIOD OF TIME IS A WEEK - MONTHS. YES BEHIND THE DRIVERS SEAT, AND THE LINE GOES DRY. WE THINK ITS A FUEL LINE PROBLEM AND LIKE YOU SAID ITS SYPHONING BACK TO THE TANK. IF I RUN THE TRUCK EVERYDAY IN GOOD WEATHER I DON'T HAVE A PROBLEM. I WAS THINKING OF REPLACING THE FUEL LINE AND SEEING IF THAT WOULD HELP.
#36876 05/23/2003 4:13 PM
I assume you have the one barrel Rochester "Leakmeister Special" for a carb. More than likely the problem lies in the carb, which is next to impossible to seal properly.
If your fuel line is all steel tube from the tank to the carb, you probably don't have a problem there. If the steel tube is spliced to rubber hose, there's a good chance for a leak. If so, get some Permatex Hylomar sealant (gasoline compatible) and seal the connections.
Fred
52 3600
69 C-10
#36877 05/23/2003 5:46 PM
FRED I DO HAVE A ONE BARREL ROCHESTER. WHEN YOU SAY LEAKING DO YOU MEAN LEAKING SO I CAN SEE A PUDDLE ON THE FLOOR, OR IS IT LEAKING TO SOME WHERE ELSE? I ASK BECAUSE THE ONLY LEAK I HAVE IS A OIL LEAK.
