0 members (), 115 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
Speaking with Tom Langdon last night he mentioned that the face of the hydraulic lifter should be slightly convex. Although my engine reman shop assured me that they had sent my lifters out for refurbishment I discovered today that the faces are a plane surface. When I put two together there is a solid mating surface between them.
Vintage Auto Parts states that they can regrind lifters to original specs.
Comments?
Don
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
Tom is correct. The convex surface is waht causes the lifter to rotate as the engine runs, which actually helps decrease the overall wear. This goes for solid lifters, too. Do you have a true surface to check them on, like a flat plate of glass? If they are truly flat, then the whoever "refurbished" them did not do the job correctly.
Bill Burmeister
