4 members (Steelonsteel, FishinToms53, Gdads51, 1 invisible), 126 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#368093 01/30/2008 4:29 PM
I'm looking for all opinions. I will be buying a kit (not retrofitting). What is your choice? Power master brake mounted to the fire wall or under the cab?
I personally like the under floor booster/MC kit. I have done several of them. The firewall set up is just more to clutter up the engine compartment and the pedal will not match the clutch pedal. If you are not interested in the stock look or have an auto trans it probably doesn't make much difference.
Fred
This is where I got mine. Chevy Duty sell the same product. They buy them from Classic Performance Products as well.
You can get drum/drum, disc/drum or disc/disc/
http://www.classicperform.com/Store/1947_59_Trucks/4754BBD.htm
~Jim
