| | | Forums66 Topics128,194 Posts1,057,248 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Aloha nui loa, i'm sure this has been answered before but didn't see anything in the archives so: My'51 is slowly leaking gear oil from the tranny, down the torque tube and into the rear end, I've just gone on a schedule of draining the rr end and re-filling the trans, someone mentioned the fix, some kind of bushing(?) with a funny name, and said it wasn't easy and if it has been done once already your kinda dead in the water. Any help and/or suggestions? Many Mahalo's | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | "Okie" bushing .
Try Jim Carter , I have had them from him several times . | | | | | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Kimo, be sure you keep that transmission oil up utill you install the Okie bushing. You don't want that tranny to run dry. That could cause major problems.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
